"get the 450 MHz and overclock it to 500/550".
I know that's the response I would get if I asked which one I should get.
But do the makers really do anything more than just set the default speed higher?
so if I got the 550, and compared it against a 450 OCed to 550, would it be EXACTLY the same, performance/heat/longevity considered?
Or are the 500/550s actually clocked higher by design, and can OC just as well as the 450?
i.e. 550->600/650.
i.e. 550->600/650.
