Been reading some things that the7800GT needs a lot of power otherwise you get artifacts...what is a good psu for this card (I also have a dual core processor)
OCZ is a dressed up Fortron with stiff cabling. Antec is made by CWT and CWT is having a
love affair with FUhjyYU capacitors, a KNOWN bad brand.
Do you want modular, 80mm fan for cross flow cooling or 120mm fan for less effective
but good downward cooling.?
Search the Enhance PSUs at http://www.ewiz.com/ . Look at the spec at http://www.enhanceusa.com/
Enhance is a known high end builder of switching power supplies.
Several of their high output units are listed at http://www.80plus.org/
