EVGA 680i MOBO 4-Pin Power connector (PWR3)
Hauk
2,806
The manual says it's "Auxiliary power for graphics."
I'm running one 8800GTX which already has two PCI-E power inputs. Do I need power to the 4-pin PWR3 on the mobo as well?
P/N: EVGA 122-CK-NF63-TR LGA 775 NVIDIA nForce 680i SLI ATX
Hauk
2,806
Thanks for the link. I tried EVGA but came up empty. You search good. :)
I'm gonna run without it. Sounds like it will be okay. Funny how there's no solid answer to when you *are* supposed to use it, ie two or even three PCI-E cards. I think I'll bug EVGA for an official answer.
Hauk
2,806
EVGA rocks on customer service. I've had good experiences with them. I just got a call back within 10 minutes of leaving a message to tech support.
They said to use the 4-pin conn in SLI configurations and above (physics+sli). The 4-pin connector provides power to the PCI-E bus but not to the cards. Helps with stability with oc'ing. There's no chance of overvolting a powered card by using the conenctor too.
lopri
13,310
687
You mean, the molex connector next to memory slots? DEFINITELY CONNECT IT if you're overclocking CPU/memory. From my experience it has little to do with the graphics, but rather memory. But if you have no problem without it, then no worries of course.
HeatMiser
104
From what eVGA has said, the 4-pin molex connector provides additional power to the PCIe slots. As SteelSix said, you really only have to use it if you have SLI or run a second PCIe card. Should have nothing to do with cpu/mem, but if you find that your PC is more stable with it plugged in, then by all means plug it in.
