Evercool VGA Cooler and noise with DFI NF4 mobo
Originally posted by: nealh
Ok..the DFI fan is very loud as many have complained..looking to change it out..I got a Evercool Twinkling VGA Cooler that is supposed to fit ok
http://www.jab-tech.com/Evercool-VC-RE-Twinkling-VGA-Cooler-pr-2291.html
I plugged it in and fan makes a whining noise from the "motor" not from speed of the fan
wondering if anyone else has this issue...overall seems quiet but the motor noise is something I seem to hear
Yeah, this is my experience with it. My stock fan developed bearing wobble, so I had to ditch it. (That's my second bad experience with SUNON Maglev fans.)
Try setting the temp controls for the NF4 fan in the BIOS' PC Health section - Fully OFF below 25º, fully ON above 55º. That'll pull the RPMs down to about 3K and quiet it down.
I did this except I set full to 50C
But the other reason for considering a change is better cooling???
Welp, my experience is that the Evercool *is* better performing than stock, but not by much. Maybe 2º C or so. We can all thank DFI for limiting our choices on better performing chipset coolers - it's either the Evercool, or maybe a copper Iceberq, or throwing the GPU into the lower lane and blocking a PCI slot...
thanks..probably really not worth the hassle then...
Jeez 2nd HSF for the chipset I bought..first was a vantec copper but it needed modification to fit..so I sold it...
well I may at some later date hassle with this....just such a pain to remove the mobo...besides it is not going to affect my oc..just though it might be worth lowering the temps
