I'm trying to find this fan in the 2 bearing model, any suggestions? How do these compare to the other 120mm fans out there (dba to cfm)? Thx in advance.
aluminum case fan.
aluminum case fan.
Originally posted by: Murd0ck
Right on, thanks for clearing that up for me. I think I know what to shoot for now.
It seems like using the larger fans on slower speeds can have equal or greater cooling power while making less noise than the smaller fans?
I would like to have a 4 fan controller with the rheobus that goes from 0-12v and that can handle upwards of 100watts through at least 1 channel(for pump), yeah I know, "forget about it" right?
A temp monitor and a rheobus control for my fans and pump would let me basically "tune" the system on the fly, that would be cool 🙂
So If I had 2 120mm fans on one radiator could I run both of them from 1 "channel" on my rheobus thing? Since they would both be doing the same thing they could always be at the same speed right?
