Evercase front USB leads
daveshel
5,453
I got the Evercase special from Newegg last month. Has anybody figured out the coding on the front panel USB leads? The labels don't correspond with those on my 8KHA+ header.
Amber
577
This worked for me
pins #
1 2
3 4
5 6
7 8
9 0
#1 ORANGE/GND
#3 RED/DATA+
#5 BROWN/DATA-
#7 BLACK/VCC
#0 YELLOW/VCC
#2 GREEN/DATA-
#4 BLUE/DATA+
#6 PURPLE/GRD
#8 WHITHE/SHELL
nerdherd
207
Amber, did your mouse become invisible after plugging in the usb leads. My 8kha+ has 2 extra rear usb ports and when I installed it into usb2 in the mobo, my mouse became invisible. Connected it into the ps2 port though. Do I need to install it into the usb port for it to work? Thanks in advance.
DaiShan
9,617
nerherd, your dilemma sounds like a problem with the via chipset, did you try the suggestions we left in your thread?
nerdherd
207
Daishan, I tried the update on the 4in1. So far no lock ups when booting up. Earlier, I encountered a new proble, it got to loading win2k, after that bar at the bottom gets filled up, then screen went black. Had to reset it. Happened only once.
Haven't tried the www.usbman drivers as the only ones I can see is for the win xp.
