I am getting ready to upgrade once again. (it has been a while)
I am looking at going Matx this time, so my case choices are somewhat limited.
Here is my front runner: EverCase ECE3505 - NewEgg pics
It can be purchased for <$50 shipped. without a power supply.
My biggest concern is how sturdy it will be. I don't have any problems modding the fan grills which don't appear to be the greatest.
Other cases I am considering are: SILVERSTONE SST-TJ08-B
I like the front bezel, but it looks kinda cheap inside. I especially don't like the HD mounting solution. Included fans are a plus though, and no mods necessary as well.
and this one: COOLER MASTER Centurion 541 RC-541-SKN1
My biggest concern with this case is: it looks like it will have a hot spot @ the video card unless a vga silencer is used to exhaust heat.
The power supply I have to use with this build is a PC Power and Cooling Silencer 430. It is a single fan solution PS that won't contribute to case cooling other than cooling itself.
If you have used any of these (or any EverCase models for that matter) your input will be greatly appreciated!
Thanks! 🙂
Thanks! 🙂
