A couple of days ago my HTPC started crashing on me.
I figured dust build-up was the culprit, since I have been remodeling and there's been a lot of drywall dust floating around.
Well, I cleaned that out and noticed that my video card fan had crapped out (once again
It's an old Radeon 7500. Not really worth the cost of a new fan and I have brought it back about 3 times before. OK, new card on the way, but noticed something strange.
I normally install UD on my PC's. This program keeps the CPU @ 100% so it generates a lot of heat. With UD running, once the CPU heats up (keeping in mind dead vc fan is keeping temps higher than normal) the PC would crash. I can faintly hear the seek sound (except pretty quietly) that a hdd make when it is failing.
Now, if I don't run UD, it won't crash at all. I also double checked by installing prime95. It caused the same crash scenario. (No overclocking...will normally run prime95 indefinately)
I am going to make up a boot cd with testing software for Samsung drives so I can verify I haven't borked my drive. I have just never run into this before.
Anyway software temp readings are bogus:
idle- CPU-38C, mobo-19C (75F in the room
load CPU-47C mobo-28C
