So, I've been doing some reading about evaporative cooling systems... Here in FL everyone has their air conditioner running approximately 22 hours a day... but we don't have these "swamp coolers" that apparently are common in places like Arizona?
For those that don't know, basically it's an air conditioner, but it works by wetting a membrane with water, and then blowing air across the membrane. As the water evaporates, the air is cooled. This is obviously a much more "environmentally friendly" method of cooling off your house. However, there are a number of disadvantages, the biggest that in humid climates (IE Florida) you'd end up with a rainforest in your living room with 130% humitidy.
But what I'm trying to figure out is this (and I have seen some passive references to doing this online) ... why not combine the evaporative cooler with the standard outside A/C condensor? What would happen if I surrounded my A/C condensor unit with evaporative panels? Presumably it would become more efficient, yes? The air blowing past the coils would be cooler than the normal outside air, and thus the compressor could run less to cool.
I guess I'm confused as to why I've never seen anything like this. ?
