As I upgrade my home network I'm realizing that I'm a tech dinosaur. My needs are basic: medium sized house, two laptops, two cell phones, two smart TVs, and a printer. Shopping, surfing, and emails. No heavy apps or large file transfers.
I purchased a Netgear modem, CM1100. Still undecided on a router but I'm ready to go with the RAX40. With two ports available on the modem, I was assuming my laptop is wired directly to the modem while the other port connects to the router. Then I read about something called Ethernet Port Aggregation which suggests I connect both modem ports to the router. The laptop would then be wired to the router, as well. Is this correct?
What is the advantage of this setup?
Will it make a difference in the network I described above?
The literature on the RAX40 doesn't mention that it supports ethernet port aggregation. So is it still advantageous to wire it up this way?
Sorry for all the questions. Just trying to learn and understand. Thank you.
