Ethernet, Firewire, USB 2, Wireless, FASTEST?
21stHermit
927
I currently have 3 - external enclosures (2 - HDs & DVD burner) connected to my laptop via USB 2.0. The speed is okay, but cluttered and noisy.
Because I'll soon switch from a satellite modem to wireless broadband, Thought I'd kill two birds . . by setting up a NAS. Therefore what will be the real world performance of 10/100 ethernet storage vs. my existing USB 2.0 HD array? A wireless router is also an option.
Toms Hardware just published this Bandwith Comparison, scroll down. The table didn't include 10/100.
Aug 23, 2000
15,509
Firewire is going to be the fastest. If you want to go with a true NAS then ethernet is the way to go. You can plug a NAS device into the network and anyone with permissions can connect to it. If you go with an external drive like a firewire or usb connection, then the machine that it is attached to must be on too.
TMY
34
It really dpends on how will you use your NAS. My own experience toward NAS was not as good as I expected. Espeically when I tried to use 3 computers to access my NAS at the same time, it dramatically dropped down the speed. Not only b/c of the hardware, but also the software problem. My NAS was cheap, an ARM OS in it. I guess that's the reason.
If you would like to have a better proformance, FW800 (1394B) is the best.
Try http://www.CaliforniaDrives.com
or http://www.macsales.com
