Ethernet: Connecting two computers
arcenite
10,660
7
I am trying to network two computers in my house, is that possible to do w/ internet connection sharing without the use of a router? If so, how? I have been trying to get the two rigs (both are w2k machines) to see each other, but they don't.
Thanks.
Bill
Matthias99
8,808
You need a crossover cable for a direct NIC-to-NIC connection; you should be able to pick one up at CompUSA, Radioshack, Best Buy, etc. Once you connect them with one of those, they should be able to talk to each other (assuming they're set to be on the same subnet, etc.)
Slappy00
1,820
4
I wondering if you can do that with USB also (a direct computer to computer connection)?
JackMDS
29,547
423
arcenite
10,660
7
Originally posted by: JackMDS
Yeah, if you want to Fry the Mobo.
aRCeNiTe
May be this can Help.
Link to: Windows XP Internet Connection Sharing.
If you are on Dialup you choices are limited.
Hoever if you have broadband you are going to make your Interent Expience Quirky by saving $9.99.
Link to: 4 Port Cable/DSL Gateway Router. $9.99after rebate.
Thank you :)
Bill
TechnoPro
1,727
Actually, there are USB cables specifically designed to network 2 PC's. Here's one. Clearly, you will not obtain the same speeds as you would when using a crossover cable, but the technology does work.
