Ethernet card acting strange
Osteole
60
AFter some badly needed cable management and installation of shelving system, I plugged my computers back into the network, but now my desktop isn't connecting correctly.
When I used 192.168.1.1 to check modem settings, I would get no connection detected.
I then looked at IP address which was fine, did a release and renew and now the IP is zero. I disabled, enabled still zero.
I uninstalled the ethernet card, rebooted, now its says media disconnected.
Help!
May 16, 2007
61
Try entering a manual IP address and see if that works, and how exactly did you "uninstall" the card? Was it a physical removal or did you get rid of the drivers?
Osteole
60
I uninstalled the drivers, and then reinstalled using the disc provided with the motherboard.
