etherant2 problems
snowdawg
my isp and i have been going round and round again time after time.
i know that my problems could be some what on my end but im thinking not entirely.
old etherants you could telnet in and do what you needed to and check it out,clear events logs etc..... .
my problems started again last week or so....it just up and croaked....couldnt get in or out with the wireless.....they replaced antenna with etherant2(radio/antenna built together) ..... now it seems to up and die when it wants..and comes up when it decides. usually up bout 10minutes at a time...give or take. i can not get into the box hooked directly to the wireless...from the inet. example via remote desktop,ftp,vnc . i do however have winroute running on that box to get the lan online....can get in from lan with no problems.
i have also posted below the only info i can get off the radio. if anyone knows what it means or has any info that could help...i would greatly appreciate showing up my isp heeehhehe and get my wireless working the way it was intended.
i personally replaced some stuff with " XXXX " to either hide my ip....and or other info that wasnt important enough to post.
=-=-==-=log=-=-=-=-=
Test page from the EC-II micro-server Ver: 1.01 - 05/24/2002 @ 12:33pm
< < < < < < < < < < < < EC Settings > > > > > > > > > > > >
EC-1 System Time: 675722
Network Settings: 10 Mbps, Half Duplex Mode
. IP Address: 12.19.x.x
. Mask Address: 255.255.255.0
. Gateway Address: 12.19.x.x
. MAC Address: 00:06:11:00:x:x
< < < < < < < < < < < < Scan Networks > > > > > > > > > > > >
Scan returned 1 network(s):
Network(1): Cyberxxxxxxxxx
. Network Type: Infrastructure
. Channel: 4
. Encrypted Data Only: NO
. Beacon Interval: 100 milliseconds
< < < < < < < < < < < < Connection Overview > > > > > > > > > > > >
Connected to network: Cyberxxxxxxx
. AP Name: Suncom PValley
. RSSI : -60
. Channel: 4
. Encryption: OFF
. WEP Key Size: 128
< < < < < < < < < < < < Details for this Link > > > > > > > > > > > >
Link Test Returned
. This Station: Dethxxxxxxxxxx
. Test Partner: Suncom PValley
. This Station Signal : -61
. This Station Noise : -98
. Test Partner Signal : -62
. Test Partner Noise : -91
. This Station Rate : 110
. Test Partner Rate : 55
. This Station MAC address : 00:06:11:00:x:x
. Test Partner MAC address : 00:02:2D:29:x:x
=-=-=-=-==-end of log=-=-=-=-=-=
thanx to all in advance for any and all help.
snow
