Hi everyone,
This is my first post and I was wondering if anyone had the expertise to advise me on what I'm doing and the best way to go about it.
I've decided to design an implement a honeypot for a small-medium enterprise (SME) as my final year university project. The plan is to host 1/2 honeypots and an IDS/Firewall on a single machine running as ESXI instances - the specs of the machine are: 8gb RAM, 3ghz quad core cpu, 1TB HDD.
This will be hosted at my parent's house and administrated remotely by me over the internet. I plan on doing this either by a VPN with a Raspberry pi as the VPN entrance point or an SSH tunnel. I then plan on port forwarding the necessary ports in order to be able to use Vsphere remotely to configure the VM's. Do you think this should work?
Security wise I plan on having a virtual firewall to supplement the crappy existing BTHomehub and the honeypots and firewalls will need to be put in a DMZ so they don't have access to my LAN. Can I put more than one device in the DMZ by use of a esxi virtual switch or by using a virtual firewall? The homehub will only allow me to put one device in the DMZ.
Please let me know your thoughts on this project and any suggestions you may have.
Thanks!
Jack😀
Thanks!
Jack😀
