Originally posted by: Rogue
I had the rocket that had a clear "payload" section in it and let me tell you, anything that would fit in there got sent for a ride. We used to grab large grasshoppers and load them in there and shoot them.
Heh, I had one of those. Good times. No insect or small reptile was safe
90% of the time, our unwilling astronaut made it back alive, too :Q
Also fun was building small rockets and gluing the nose cone on so that the chute ejection charge in the engine would cause the rocket to explode...or loading the body of the rocket up with small explosives tied to another fuse, so that the thing would blow apart / catch fire on the way up (or down)..
Once my friend built a rocket with a glued in, weighted nose cone and two engines in it. He timed the engines to fire a certain distance apart.
The end result was that the rocket would go up...no chute would deploy, since the nose was glued on (he vented it so that it wouldn't explode when the charge went off). The weight in the nose would cause the rocket to turn over in mid-air, after the first engine had expired, so the nose was pointed at the ground....and then the second engine would fire, sending it to the ground at ludicrous speed.
That rocket worked TOO well. Quite a scary experience - it almost took my head off when it came down, and COMPLETELY exploded when it hit the ground.
We never did that again. Quite a stupid idea, although it was cool as hell.
