ESATA External Drive with 5400rpm?
LOUISSSSS
8,771
58
which of the above choices would give me better file transfer speeds?
i'm guessing the 7200rpm with the USB
Zepper
18,998
eSATA will always give best performance but a port isn't available on many computers yet. So if you are using the external with many PCs, USB will do you better. Why not get an enclosure with both types of ports like the new Silverstone MS05. I've got one here and have only inspected the product in detail preparing to review it - still waiting on the drive which I bought on FleaBay. So far all I'd like to see on it is some rubber pads on the drive enclosure itself for a little non-slip when using it as a portable. It's similar to the Vantec EZ Swap kits as it has a bracket to mount in a 3" bay or an adapter bracket - unlike the Vantec, it doesn't come with the 5" bay adapter.
.bh.
corkyg
Elite Member | Peripherals
27,370
240
eSATA @5400 will run rings around USB @7200. I have both. I have a pair or Vantex NexStar externals which have both eSATA and USB 2 ports. Then I use an eSATA PCMCIA (Cardbus) card as an interface on my laptop and an eSATA port on the backplane of my Desktop. I can move the drives easily back and forth between my computers. Comparing actual data transfer between eSATA and USB is about 4X faster with eSATA - using the same drive.
eSATA_USB
LOUISSSSS
8,771
58
damn so transfer times with an ESATA 5400rpm drive will be much faster than a USB 7200rpm drive? wow... did not know that
NoelS
566
eSATA is about 4 times faster than USB. The HDDs transfer rate can't make up that kind of difference
Noel
