- Oct 9, 1999
- 21,019
- 156
- 106
Building a new PC and would like to be able to accommodate eSATA devices. I have no experience with SATA devices and I don't know what the difference is between "eSATA" and "power eSATA".
From what I can figure, regular eSATA devices connect to both an eSATA port on the PC for data AND also connect to a USB connection for power. I take this to mean an eSATA device has two ports, an eSATA port and a power port, and use two cables.
The newer "power eSATA" ports on a PC handle both data and power on a single connector. Does that mean the devices attached to a "power eSATA" port have to be "power eSATA" devices? Or does it mean just use a special cable with a "power eSATA" plug on one end which splits out into eSATA and power connectors at the device end like this one pictured? And does the device end of the cable fit every eSATA device?
Or am I way out in left field?
