If so, this error indicates that Internet Explorer is trying to close an add-on applet and is not able to do so because the memory where it things the add-on is loaded cannot be read. This usually happens because of one of two things. Either:
1) One or more of your RAM chips in your computer is going bad (which should be tested using MEMTEST).
or
2) An Internet Explorer add-on is not closing properly when IE tells it to. To correct this, click on Tools>Manage Add Ons... in Internet Explorer to see what add-ons you have installed. If there is anything there you don't want or need, uninstall them. If that does not fix the problem, then disable the remaining add-ons one at a time until the errors go away. When you find the problem add-on, uninstall it, download a new copy and reinstall it.
