"Erratic" Power Led = Dead Mobo?
Biggs
My old, trusty Supermicro P6SBA(i440BX) mobo suddenly just hanged in Windows, thus I turned-off the power a few seconds then restarted it. However, the system wouldn't even beep now and I get a message on the monitor, "Please check your CPU and cables. Monitor is working fine.". I've done the whole nine yards of stripping everything to basics, removing this and that, reseating this and that, clearing the CMOS, fiddling the jumpers, you name it. However, the system LED either just lights up a couple of seconds then shut's off for about 5 seconds, lights up again and so on. I also know the speaker is working because if I remove the memory completely and restart, the system would beep continuously -- indicating a memory error. The bottom line, my friends, is my mobo dead? Thanks.
Ditto on the power supply. If you can get a good known working spare power supply, try that. If to no avail, try another. If that one fails, it's probably time for a new mobo.
I did and all of them looked fine. Funny thing is, the first time I turn on the PC, the power led would exhibit the "erratic" behaviour mentioned above. However, after I've turned it off then turn it on back again, the power led wouldn't light up anymore.
