Erase HDDs A Quicker Way?
Sammy5000
Hey All...
Please excuse the newb question here. Is there any way to erase the contents of a hard drive without actually hooking it up to a PC? I took down a system which had three SATA drives with a blown mobo. I wanted to clear out the SATA hdds, but since I do not have another mobo (with SATA), I think I am stuck.
Any thoughts? Thanks in advance, folks.
Just get a cheap SATA adapter. Only around $20. There's no other way to get rid of the data than using software like Eraser or crushing the drive with a steam roller or trip hammer. You could use a stand-alone drive tester/cloner but those cost as much as a PC...
.bh.
.bh.
Agreed you need a program that will zero out the hard drive completely otherwise the data can be recovered with a few off the shelf programs.
Bang the drive on concrete a few times. Asphalt will not do because it is softer than concrete.
I saw video tape erasers on ebay for like 40 bucks its basically a super magnet that you need to plug in ...not sure if it would have any affect though...just seems cool
.bh.
You can recover data with off-shelf software?? I didn't know that... I thought you had to take them to an expensive lab for that kind of work. What are some examples of these programs? I am bored and curious about what's on my HD's empty space 🙂
Don't use a magnet unless you want to destroy the drive.
I use UniversalBootDisk to zero write the disk.
I have partition magic 8 installed, and I found under Delete Partition there's an option for "Secure Erase". That should be sufficient for making data recovery impossible, correct?
