Equation for calculating body fat?
Riprorin
Banned
Apr 25, 2000
9,634
Does anyone have an equation for calulcating % body fat from weight/physical meaurements, ie neck size, waste size?
Hayabusa Rider
Admin Emeritus & Elite Member
Jan 26, 2000
50,879
4,266
Nothing accurate. Fat distribution varies. You can use calipers, and that would be better, although ultrasound or getting measured by displacement is more reliable.
screw3d
6,906
Even those methods have a hundred variables that could screw it up! There's no way that you can measure body fat on your own..
alocurto
2,174
if you can walk up a flight of stairs without collapsing you are all set.... I cannot :-(
illustri
1,490
if you're talking about BMI: body mass index, it goes by height and weight
you want to get a score of ~25 otherwise you're overweight
the equation i read in glamour once but forgot
BennyD
Banned
Sep 1, 2002
2,068
my bmi = 25.1 :D
Bignate603
13,897
my bmi = 25.1 :D
My BMI is 17.6
HappyPuppy
16,997
If you are dwelling on it, then you sir ARE A FATTY!!:D
alkemyst
83,769
19
The measurement thing only works for average people....the three skinfold measurement is a lot more accurate.
The two most accurate is water weighing and a radio wave or something one (I am a little sedated now ;) and don't want to look it up ).
Alot of the height/weight type measurements are way off for athletes, I was 189lbs (5'10") and maybe packing 10% body fat at most...my life insurance was deferred until I saw a physican for evaluation as I came up either obese or severely obese by their standards.
goog40
4,198
How accurate are those scales that determine your body fat % by sending an electrical current through your body?
alocurto
2,174
Hahaha
