Discussion EPYC 7542 vs Ryzen 5950x in WCG
Markfw
May 16, 2002
26,129
15,274
OK, the new one is on. The only windows install of a 5950x. Memory is 2 3600c15 and 2 4233 c19 memory. It will not even post set at 1.375, 3600 cl15. Its at 3200 c16 4 x 16 gig sticks. CB23 was only 23k. Isn't it supposed to be 28k ? CPUZ and Ryzen master say the memory is at 1600 ??? This is also the ONLY x470 chipset motherboard that is running a 5950x. temp is 75c, all-core at 3700.
cellarnoise
746
404
Pump up the ram voltage more? Say 1.4+. I run some of my cheap ddr4 at 1.45 for years.
CB23 should be 28k+ with decent cooling such as a 140mm tower cooler with 1 good fan.
Markfw
May 16, 2002
26,129
15,274
it boots fine at 3200 c16, but in bios it says memory at 3200, windows and cpuz say 1600. I just tried Ryzen master, set memory to uncoupled, and 3600/1800. The profile shows that. The main tab says 1600 ! cpuz says 1600/1600 @! What in blazes is going on ?????
Skillz
963
996
Isn't that normal? CPU-Z shows the "single rate" speed and since it's "double" data rate memory you simply multiply that number by 2 to get the actual speed. 1600 * 2 = 3200
Or am I missing something?
See mine? My memory is DDR4 - 2400, but it shows 1200 because 1200 * 2 = 2400
Markfw
May 16, 2002
26,129
15,274
No, it is supposed to show 3200/1600.
Icecold
1,100
1,028
I'm pretty sure that's normal Mark. This is how my RAM shows in CPU-z and I'm confident it's DDR4-3600MHz and is set to that XMP profile- (ninja'd by @Skillz )
Reactions: Skillz
Icecold
1,100
1,028
OK, I have not looked in a while. So why are my numbers so low ?
I'm assuming 'CB23' is Cinebench 23? If so I'm not sure I've never benchmarked my processors with that. I usually just eyeball it when running BOINC compared to other PC's I have to make sure none of my PC's seem out of line as far as expected performance. I also run my Ryzens in eco mode so I'm not necessarily after top performance.
Markfw
May 16, 2002
26,129
15,274
Well, I had a week study above. So far all I have is one or two units. 1:50 for new vs 1:45 for old. old=linux, so that could be the difference. Running 68c on a 240 AIO with 31 units processing, and Ryzen master says 90% of 142 watts, 93% CPU usage. 97% is the max allowed, so I think its doing OK.
Reactions: Icecold
