ok i pushed the fsb to 165 and the system will post maybe half the time but i can't get into the bios, how do i reset this so i can go and lower the fsb?
look in the manual...there should be a jumper...you can also try lowering the multiplier down really low and see it posts...then quickly go back into bios and lower the fsb...and then set the multiplier back...
