Epox USB Problems
wfbberzerker
10,423
I have a Microsoft Intellimouse w/Intellieye, which hooks up to my computer using the USB port (or PS/2 with an adapter). Before I upgraded my computer, the USB connection was working fine. Now, the mouse will work fine, but whenever I restart my computer, there is no mouse detected. If i unplug the mouse then put it back in the usb port, it is re-detected, and it starts working again. If I only have the mouse in the PS/2 port, it works fine. Can anyone help?
Mem
21,476
13
You could try this fix as well,
<< USB Devices May Not Work in Windows 98 Second Edition
Universal Serial Bus (USB) devices that are plugged in to a computer running Microsoft Windows 98 Second Edition may not work if the your computer uses the following hardware components:
An AMD processor (running at 350 MHz or faster)
A VIA Technologies USB controller
This behavior occurs because there is a timing-specific problem in the Universal Host Controller driver (Uhcd.sys), which may prevent USB devices from enumerating under specific timing conditions. To resolve this issue, download and run the appropriate file for your language version of Windows. The following files are available for download from the Microsoft Download Center:
From
here
