I got mine from NewEgg yesterday (I had no idea these were so popular, I guess I just happened to order at a good time when they had them in stock). Excellent service from NewEgg as always, I wish I could say the same about UPS, perhaps they need to send their workers to a geography class because they should know that Des Moines, Iowa would not be my local facility for my house in St. Louis, but whatever.
This was my first time working with an SFF PC. Every time I've worked in a PC, it was at least a mid tower, and I'm a Mac guy so I usually don't mess with PCs to begin with. I already had a PVR with a PVR-150, Athlon XP Barton 2500+ and other various parts in a cheap case, but the motherboard crapped out. Which was a good thing, because I was waiting for an excuse to buy a SFF because the old one was LOUD, I couldn't even leave it on at night since it's 5 feet from my bed and I'm sure I missed out on shows.
Installation was very straight forward. Which was good, because I found the manual to be lacking somewhat, and it was poorly translated to English so parts didn't make sense. But the detailed pictures and common sense made it easy. My biggest gripe was that the power plug for the hard drive seemed to be upside down, so it took a bit of work to route it correctly so I could plug it in, they don't give you a lot of room to work with. Other than that, it was fine. Getting the PCI card in there was a bit tricky, but I still got it in. The heatsink went on without a problem, the drives went in without a problem (although it takes a little trial and error to get the CD rom drive in there so its lined up with the door and all that).
My main concern is heat. Before I installed Windows, I let the PC health screen sit in the BIOS, and my temps were in the upper 50s idle. I removed the heatsink, removed the thermal grease that came on it and put some Antec grease (i think its an AS5 knockoff or something) on there, and now the temps are in the lower 50s. I know that Athlons run hot to begin with, and there's hardly any room for airflow, but I still worry a bit. I'll continue to monitor them...which is easy thanks to the LCD screen.
The Windows MCE 2005 installation went OK and in no time I was watching TV. This thing is quiet, I can finally watch TV without having to crank up the volume to drown out fan noise. I'm using the composite S-video out, and video quality is fine in the MCE interface, obviously, you can't really use Windows though. I'm using coaxial S/Pdif out to my receiver, and that also sounds great.
Now, the cons, and none of them are really showstoppers either:
1. The display is nice, but it's a 24 hour clock, no way that I know of to make it a 12 hour clock. And it's bright, which can be distracting when trying to sleep or watching movies with the lights off, there's no way I know of to turn off the backlight.
2. It would be nice if the built-in IR sensor can work with the Happauge remote so I don't have to use that external IR receiver. I'd assume the IR sensor could pick up any commands, I think it's just more of a matter of someone needing to write a driver.
3. I'd much rather have an additional PCI slot instead of the AGP slot. I figure most people will be using this as an HTPC, and it's got everything you'd need on board. S-video out and composite out. There's no reason I could think of that one would need to add a 2nd video card. I'd much rather have the extra PCI slot so I could throw in another tuner.
4. Room for a 2nd hard drive without losing the card reader would be nice, but I'm not sure if they could fit in a 2nd bay even if they wanted to.
5. PS/2 ports on the front is the dumbest thing I've heard of. I don't have a keyboard or mouse connected, I control mine with VNC (or the remote obviously), but for people who will be using this with a PS/2 mouse or keyboard, this is just dumb.
6. SATA would be another plus. I have a 250 gig IDE hard drive so I don't need SATA, but I'm sure others would like it. Plus you never know when a 400 gig SATA drive will pop up for 100 bucks on the various deals sites out there
I can't say how well this thing overclocks...I won't be messing with that. If anything, I'll underclock to help with the heat problem. Since the 150 has a hardware encoder, I figure that reducing the processing power shouldn't have a negative impact.
And is it me, or is this product completely removed from the NewEgg site now???
