Originally posted by: lednerb
BIOS is surprisingly good IMO for SFF. No 1mhz FSB adjustments but good CPU and mem volts adjustments, multiplier adjustments.
Tried with 2500+ Barton and no-name TCC4 2x 256. Haven't tried OC'ing much since room is hot and mem isn't the greatest. Also haven't tried playing MP3s.
Lemme know if you want more info.
Great overclocker that does do 1MHz FSB adjustments. Select Expert in Bios.
Using it with an AXP-M 2400 at 203x11 or 2233MHz. Running about 52C.
I have several SFF and HTPC's and this is by far the quietest stock, as drives are louder than fans.
No floppy header (if you need floppy and can't use USB).
Front LCD display time in 24 hour format, not 12 hour, and shows time even when turned off.
Bios shows Nov 2004 while website shows latest as Sept 2004...
One of the best for pre-wired cable routing.
Just started installing Windows, so won't know more about it's HTPC and HDTV performance until tomorrow.
TV out usually blows with nvidia, so I'm expecting to have to install an ATi card, but we'll see.
EDIT: Tested video out (TV Out), and it is better than most nvidia boards. On a scale of 1-10, with 10 best, most nvidia TV-Out's would rate about a 5, while this Epox rates about a 7, and if you went with any ATi TV-Out, the ATi would rate a 9 in comparison. This Epox should be good enough for most, as long as you have a very sharp and crisp TV.
