Mem
Link to the Epox nForce 2 board info (EP-8RGA+),seems like we are waiting ages for these boards,
EP-8RDA+ info .
EP-8RDA+ info .
Originally posted by: jandaman
Can't wait but what does this mean:
Network 2 x Nvidia Nforce2 10/100Mbps (1x) & Realtek RTL8201L/ICS1893AF (1x)
??? It has 2 nics?
Originally posted by: RanDum72
Epox still has the ATX power connector at a bad spot in the mobo🙁. I'm waiting for an Asus nforce2 borad.....
It not only gets in the way of the HSF, it also gets in the way of the exhaust fan at the rear of the case. Asus and Abit have made mobo's that deliver enough juice and the ATX connector is at a nicer spot. The placement of it has nothing to do with power delivery; Epox had that design for a while and I remember they have more problems with lesser PSU's than other boards.
Sure but in actual practice, does it make a difference? Asus and Intel boards have their connectors behind the memory slots and they are the most stable boards around. My Epox 8KHA+ has very low voltage readings with a Sparkle 300w PSu, while a KR7A is right on. So I don' t think it makes a difference at all.
Some weeks ago we have 3DNow on planet! a reliability data base for base A Main board furnished. It is part of our purchase consulting section. The reader can deliver a detailed feedback there to his Main board, was as content he, which problems there were, as became it solved uvm. As opinion pool for an interested customer, who intends detailed experiences for one board necessarily, an inestimable source of information. In addition each reader also still another Voting can deliver to his Main board. The highly transparent question: "would you buy this Main board retrospectively again?" After meanwhile over 800 contributions in this category it becomes time for a first balance. In the case of the Main boards, for which to date at least 10 Votings were delivered, the following picture results:
95,7% => EPoX EP-8KHA / 8KHA+
94,7% => EPoX EP-8KTA2 / 8KTA3(+) / 8KTA3(+) Pro
94,4% => Abit KR7A / KR7A-Raid
93,8% => Abit KG7 / KG7-Raid
90,9% => Shuttle AK31
88,9% => Abit KT7(A) / KT7(A)-Raid
88,2% => Soyo SY-K7V Dragon / -Plus
86,4% => MSI KT3 Ultra-ARU
85,7% => Asus A7A266 / A7A266-E
83,3% => Abit KX-333 / KX-333R
81,0% => Asus A7V266 / A7V266-E / A7V266-EX
80,7% => EPoX EP-8K3A / 8K3A+
77,9% => ECS K7S5A / K7S5A2
76,9% => MSI 745 Ultra
76,5% => Asus A7N266 / A7N266-C / A7N266-E
76,1% => Asus A7V333
75,0% => ECS K7S6A
73,3% => Asus A7S333
66,7% => Gigabyte GA-7VR / 7VRX / 7VRXP
65,5% => MSI K7T266 Pro / -R / Pro2 / -RU
64,1% => Asus A7V / A7V133 / A7V133-C
63,6% => Asus A7M266
56,5% => ECS K7VZA
Therefore the VIA KT266/KT26Ã Main board EPoX Ep-8kha(+) is at most estimated Main board with the readers of planet the 3DNow! Naturally both feedbacks, and Votings can be further delivered. We will draw balance also in the future in loose order always times again...
The bottom line is, the darn power connector is at the wrong spot and Epox could just EASILY redesign it without any effect on stability and power delivery. I think the primary reason for them leaving it as is is simple: it costs more for a redesign
