Epox EP-7KXA help suggestions
Cnuke
186
Do you recommend this board and are there things I should know about before buying one?
Thanks for any input that you might want to give me.
Mountain
326
got one. it works. nothing fancy, just athlon 650, matrox millenium II, pc100. freezes sometimes, think its my memory. you can push the fsb to 110 and 115 and at the same time push the memory to plus 33 of the above. it also has lower speeds than 100 fsb but why? it has an amr riser so that i think it was meant to be an oem board but that's junk. sound is ok. did the latest bios flash. it was easy. if i wanted to i would buy a 900 and do the 110 fsb to be in the "GIG" club. but i dont think the letters would appear noticably faster. what are you going to do with it? go to the epox site and go to knowledge base and type in
