Here is a complete summary of my setup and problem, any help/input would be greatly appreciated. I've been reading up on this motherboard and I can't seem to find any compatibility issues with the components and mobo, but maybe I missed something.
Thanks in Advance:
I am currently building a system with a EPoX 9NPA+ULTRA nFORCE 4 board, a Althon 64 +3500 Winchester Core AMD CPU, 1 Gigabyte (2x512mb) Corsair ValueSelect DDR400, ATI x700 GPU, 480W PSU, 180gb Hitachi S-ATA II HDD, and an Audigy 2 SoundBlaster card all in an Antec P180 case. After assembling the components into the case, I proceeded to boot up.
The first time I booted up, the computer displayed the POST screen with a monitoring program and a prompt telling me to hit F2 to continue, or Del to enter the BIOS. Also when I booted up, I noticed the nFORCE chipset Fan *directly below the CPU* was making a loud clicking noise, so I bent the metal covering out so that it would not hit the fan. I then rebooted the system, and the screen was blank. I don't believe the computer even started the POST, it went IMMEDIATELY from FF to the error message in the onboard LED-display. The onboard LED-display read d0. This error message is under the Appendix C in the user manual as 0D, which was "reserved". Nothing was mentioned about d0. I believe it's also important to note that the 3 "LEDION" lights were a bright blue throughout this entire process when ever the computer was turned on.
I read and re-read your quick start guides and manual on first boot setup, even re-installed the CPU and all the cards and cables. I also checked all jumper settings in the manual and reset the BIOS.
I am currently researching online if this board supports the +3500 Winchester I have, but since the computer entered the POST setup the first time, I believe it is compatible with the CPU. Maybe I damaged the nFORCE chip when bending the heatsink covering out.
Reply Quote Top Bottom Edit
Quick Reply
Subscribe to this topic E-mail this topic to someone. Add this topic to my forum favorites View topic in raw text format.
