Hi all, I need to get a socket A M/B and the Epox 8RDA3+PRO looks pretty good.
I just need something stable, I'm not going for high OCing.
Could anyone using it please tell me of your experiences with it.
The capacitors. They had defective caps on their boards and they would buldge and leak causing death of the motherboard. 8RDA sersies was known for this and i experienced it directly.
