Epox 8RDA+ with 5.1 speakers and NV mixer
imported_Klown
My setup is the following:
Athlon XP 2000+
Windows XP SP1
Epox 8RDA+ with latest NVIDIA drivers
Altec lansing VS3151 5.1 speakers
I have the following baffling problem:
The speakers are all connected fine. The tests performed by the speaker setup under Soundstorm (and later NVmixer) are fine. The problem I have that the bar for the Subwoofer in the VU meter under NVmixer never appears EXCEPT when I run the setup in which case it's fine, a green/red bar shows up.
If I play a movie or an mp3, the other bars show up fine but the one for the subwoofer stays dead.
NVSWAP "sees" (i.e. projects static into it) the center speaker but not the subwoofer.
Are there any other utils I can use to test the setup? The subwoofer seems to be projecting bass even when the VU meter bar is dead but it is hard to tell. I thought about trying the speakers on another machine but the Soundmax ones here at work do not have the same util for seeing the sound output, just a simple setup simlar to the soundstorm/nvmixer.
Any help would be appreciated.
