I have just upgraded my CPU to a 2500+ on my 8rda+ mobo. The upgrade worked fine at first, but then I decided to have a try at some overclocking. It went OK up to 166@12.5 - 1.8 volts, but when I tried 166@13 it would not post. No problem I thought I will just reset the cmos and all should be OK.
Not so unfortunately, the problem I have now is that the bios appears to lose its settings and I am having lockups when Windows starts. My suspicion is that my bios may be corrupt - any ideas anyone??
BTW I am using the 1/29 bios, which I flashed soon after I installed the MOBO, that was about 4 months ago and all was OK till now - should I flash a newer bios and if so which one is the most stable/problem free etc ??
Thanks
Thanks
