- Oct 31, 1999
- 30,699
- 1
- 0
I got my 8RDA+ fired up today. After running it for a while and doing some benchmarks, I got around to shutting down and hooking up the LED cables, the Antec case's front USB wiring, and a few other odds and ends.
When I went to start it up, I pushed the power button and nothing happened at all, as if the system were unplugged. So I checked the usual things and when that didn't help, I began to backtrack. Finally I unplugged the case's front-USB-port wiring and what do you know... system was back online.
Pin 10 of the USB3 header (pictured on page 3-11 of the English manual) is marked as "overcurrent." On the Asus boards I've been working with, plugging the extra Antec ground wire onto this pin works fine, but on the EPoX, it turns out to have live 5V power when the motherboard's on (checked it with a voltmeter). I got my first clue when I looked at the extra 2-port USB plate that EPoX includes, and hey, they don't have a wire in the hole corresponding to pin 10.
Taking the extra Ground plug off of pin 10 on the board is the key, if you're using some alternate outlets other than the one that EPoX includes with the board. Incidentally, the front-USB outlets on the case worked fine after I took the Ground plug off pin 10, so evidently no harm was done. Hope this helps someone down the line.
