1200 266 t-bird
radeon 64 ddr video card
256 mb cas 2 ram
I got a error message about a overclock error when booting it said to reset the clock speed and offered to enter the bios with f1 command.
I was OCing to 1330, so I reset it to default 1200 133x9.0.
Restarted everything is OK. then later on I get the same message and it resets it's self to 100x 9.0 - 900 Whats going on?
Set it back to 1200 133x9.0 and it's doing ok presently
I have not messed with voltage just sdram cycle length to 2 and enabled fast r-w turn around.
I did not know if post should go here or OC section
Thanks
256 mb cas 2 ram
Thanks
