AMD EP-8KTA 700Mhz CPU - 100Mhz FSB - 128 MB PC133 Crucial RAM - 16 MB TNT RIVA Gfx - 6Gb WD HD - 250W PSU.
Ok, lets tell you how I got ahold of this system...
Friend of mine was moving, had no room for his computer so he gave me the tower and a 19'' CRT monitor (woohoo
Well he said he had some trouble with it anyway so it wasn't a big loss.
Now onto the problem!
First off, this thing won't read CDRoms... even the one in this machine which I KNOW works.
The HD is a WD 6 GB, little yes but for a 700mhz AMD that was used for very light gaming and mostly word and email it worked.
The OS was Win98se, he tried to format to WinXP and he said thats when it wouldn't boot.
Ive reset bios to factory default, cleared CMOS via the jumper on the MB, put a stick of my 133 MHz Ram in there from an old 533 I had. Made sure I switched the Jumper on the MB from PC100 to PC133. Checked cables, they are fine.
I moved the HD to this machine and formatted it with WinXP Pro, once I was done, powered down and then put the HD in the other machine (Since I cant get that damn CDRom to work) and booted.
"Loading Windows XP Professional Edition"
BLACK SCREEN
Thats it.
I restart it asked me for the "Last known good config" and Safe mode hangs on APG440.SYS or the file right after Im not sure.
Im temped just to format that damn HD with RedHat linux for the hell of it.
The Video Card is a 16 MB AGP video card that I had in my other 533, I have a PCI that was damaged when the fan died, so it will lock a computer up if I dont keep a box fan on it (lmfao).
I've tried everything I can think of, I like the setup of this AMD and was thinking of buying a NIC and a new CDROM drive for it but don't want to waste money on a dead cpu.
ANY suggestions are welcomed.
Edit: Spelling...
BLACK SCREEN
Thats it.
Edit: Spelling...
