I just put together a new system using the Epox 8KHA+. Everything seems to be working fine but while running some benchmarks using Norton Utilities, I discovered the hard drive performance was way off.
Basic system setup is:
WinMe, AMD T-Bird 1400, 256MB DDR2100. Running at spec speed FSB and RAM timings.
The hard drive used was a brand new Maxtor 740DX - 80GB 7200rpm. I expected this thing to smoke but it is putting out a paltry 18MB/sec when doing the "Physical" read/write benchmark. I have seen benchmarks over 40MB/sec using an Abit KR7A with a WD 60GB 7200rpm drive. Even though the drive is ATA-133, both mobos support only ATA100. I had a matching drive which I installed, just to make sure the first drive wasn't defective but had virtually the same performance.
I have: swapped cables (both ATA-100/133 rated), flashed to the latest bios, loaded the most current set of VIA 4-in-1 drivers, checked to be sure "DMA" was marked in the Device Manager, configured the drives as "cable select" and then as "master/slave", stood on my head while reciting preamble to the constitution.....
I'm stumped. Anyone have any ideas? Would appreciate anyone solving this problem.
