Hello,
I am trying to quiet the PC down while doing some other upgrades. I bought a Zalman Northbridge HS and was planning on replacing the original HSF but I am not sure how to remove it. There are 4 screws on the fan itself but on 2 corners there are pushpins? I know the Zalman HS has different ways to be mounted but I am not sure which one I will have to use? Do you have to remove the MB from the case to release the northbridge stock HSF?
Anyone have this on there epox board? How did you mount it?
Thanks alot. I am still learning
