- Jan 16, 2001
- 31,528
- 3
- 76
I believe I have discovered a major glitch in the Epox 8K5A2+ motherboards.  This relates to if you are booting from the Highpoint controller, which I'd imagine most people that have this mobo are.
I have the 8K5A2+ mobo, Rev 1.0. I was using the shipping bios (August 2002) and tried to solve the problem by flashing to the November 2002 bios. The BIOS itself had nothing to do with it. It was the SETTINGS in the BIOS.
I've been having major problems w/this board...refusing to boot and hanging at the Highpoint bios. I've spent literally WEEKS going back and forth trying to eliminate the memory, the CPU, the power supply or the board itself.
I noticed that once I cleared the CMOS and "loaded optimized settings." It would boot. It would boot after I changed the memory timings as well (as long as I wasn't using Corsair XMS memory...more on that later.)
Well, I went thru and one by one (took two damn days....) changed a setting and rebooted; in order, starting from the "Advanced Bios Settings" screen.
Here's what I found out.
If you enable USB Keyboard and USB mouse support and you DO NOT HAVE A USB KB OR MOUSE plugged into the USB ports, the board will hang!
At first, I thought it was the "enable USB 2.0" setting. I was close.
I also noticed that my frickin' $200 stick of Corsair XMS3200 DDR won't boot at 166MHz with "Turbo" timings enabled. What a crock of crap. I'm RMAing this bastard and they had BETTER hook me up bigtime...$200 for a stick of memory....my first car wasn't worth $200 :| <--but that has nothing to do with this EPOX mobo.
As a general rule, when setting up a BIOS, I disable onboard sound, and enable everything else. Why? Because--- > It's not given me a hint of trouble on ANY VIA or INTEL mobo up until this one.
Has anyone else experienced the same problem with this motherboard? If not and you're using a PS/2 mouse and KB, can you go into your bios and enable USB keyboard and mouse and see if you can duplicate this problem? If enough of us can duplicate the problem, maybe Epox can work on a fix and hopefully prevent others from experiencing this same horror.
 Facebook
Facebook Twitter
Twitter
