epox 4g4a (not +) comes with lan?
ethernaut
27
if not then I shoulda just got the 4g4a+ since the 4g4a with a nic card would cost about the same :\
VSEKH
151
The I/O shield that came with my 4G4a had the metal plate intact where the lan plugs in. I took out the metal plate and plugged in the lan. The bios had a setting to enable or disable the lan. I enabled it and had lan. They do not advertise that it comes with lan. Or else, I got lucky by trying it out. Does your 4G4A have lan?
