epic armor for my rav4
Status
Not open for further replies.
brainhulk
Found a good deal on amazon for the bull bar and nerf bars.
Before
After
+1 resistance to shopping carts
+2 resistance to Ducatis
Anybody know if they make a lift kit for these? Would you guys put a lift kit on a rav4? Lol
What happens if a shopping cart attacks you from behind? You need a "butt bar" to block the blasted bastard buggy barrows of buying!
needs moar lights.
and those bolt on ones like that usually afford little actual protection. I guess it will help when you hit a big wheel on your suburban street.
don't see much shopping cart protection from the side. See one stupid bar on front that can fuck with safety systems.
does the bullbar have pre-drilled holes in them? mount some PIAA 520s or 540s on em.
the bullbar also serves as a pedestrian deflector.
Im hesitant to put any lights. I used to go off roading quite often and all the guys with extra lights would get pulled over because they didnt cover them. Too much of a PITA...
Since the advent of LED light bars, I've become entirely disinterested in traditional lighting. They're pretty awesome.
Status
