- Mar 30, 2006
- 72
- 0
- 66
Would something with power around the same level as an 8800GT be enough to run new games @ 1920*1080?
Concerning Settings:
I am not concerned with AA because the jaggies haven't really bothered me once gaming res moved up to 1280*1024, so I will likely not run any AA at 1080P resolution. I would like to be able to run new games with most of the detail options on med/high to highest settings for around 2 years hopefully. AF i would be fine even as low as 4x but would turn that up as high as I can without performance degradation.
Concerning HDTV's used as Monitors.
I am considering an upgrade to be able to use 1080P resolution in order to hook up to my Philips 42" 1080P HDTV. Any quirks or issues known that effect using HDTV as Monitor? I will be connecting through an HDMI port and will probably have to split the 1/8" Audio to two stereo RCA plugs since my old ass audigy doesn't have an optical port.
Specs are:
E2140 @ 2.8ghz
Gigabyte DS3R IP35 Mobo @ 350mhz FSB
2 Gigs Ram
7900GT
Audigy
I will have a Quad Core penyrn based chip eventually if the E2140 starts to give me speed issues but its handled everything perfectly so far. And once I need DX10 I will go vista and add another 2gb of ram so dont consider my Current CPU and Ram when making recommendation. I envision a quad core around 3.2+ghz to be on my board in the future.
Thanks in advance.
Specs are:
E2140 @ 2.8ghz
2 Gigs Ram
7900GT
Audigy
Thanks in advance.
