Originally posted by: yamahaXS
Originally posted by: MCrusty
There is a closet, a curtain, and a lamp in the bedroom.
There are closets, curtains, and lamps in the bedroom.
I think the above are correct. Except the last comma in each sentence should be deleted.
There is a closet, a curtain and a lamp in the bedroom.
There are closets, curtains and lamps in the bedroom.
Removing the last comma is optional. Typically in newspaper they'll remove the last comma to save space, but in formal writing like essays and reports, you should insert the comma.
That is incorrect.
Umm . . . right
Wilson Follett, Modern American Usage: A Guide. Edited and completed by Jacques Barzun in collaboration with Carlos Baker, Frederick W. Dupee, Dudley Fitts, James D. Hart, Phyllis McGinley, and Lionel Trilling. NY: Hill & Wang, Inc., 1966, pages 397-401.
Follett argues for using the final comma. He examines the reasons for the comma's omission:
What, then, are the arguments for omitting the last comma? Only one is cogent ? the saving of space. In the narrow width of a newspaper column this saving counts for more than elsewhere, which is why the omission is so nearly universal in journalism. But here or anywhere one must question whether the advantage outweighs the confusion caused by the omission.
Having analyzed the confusion created by the comma's omission, Follett concludes:
The recommendation here is that [writers] use the comma between all members of a series, including the last two, on the common-sense ground that to do so will preclude ambiguities and annoyances at a negligible cost.
This advice is unchanged in the most recent edition of Modern American Usage (NY: Hill and Wang, 1998) ? even though its editor, Erik Wensberg, substantially revised many of the work's other prescriptions.
