No need for cams, piston rings, ignition upgrade, etcetc...
I would tend to disagree with the ignition....I would reccomend an igntiion upgrade even on a non boosted motor. More spark, more complete burn. Also under boost, better ignition could help prevent detonation. Im not sure how the stock ignition on the probe performs. I'm not saying an all out ignition like a MSD digital 7, but something like a SCI, or 6A. Wires and plugs; well, wires, I'd go with 7mm-8mm for road application, larger (10mm) if you are going into a lot of racing on the track. Plugs, copper conducts electricity better than platinum, but are not as heat resistant and do not last as long. Perhaps iridium if they have it for your app.
More spark more burn? That's just doesn't make sense. Any spark and if the fuel is properly atomized and timed... it will burn regardless of the strength of the spark as long as you have an ignition system that is capable of enough voltage to jump the air gap. Sure, denser air adds more resistance to spark, but if the factory system provides more than enough voltage... there is NO reason to change it. I know many people deep into the 12s & 11s with factory ignition systems.
All this iridium, thick wire crap is nothing but riceboy marketing. If your application doesn't require big current/voltage, you have no reason to use thick wires other than for durability. High quality silicone wires and a set of properly gapped fresh copper plugs is just proper care of the car and all that's neccessary. Iridium is just extra $$ and platinum electrodes aren't durable enough for forced induction apps.
I agree with you on many points. The reason i would use thicker wires is for durability. In harsh racing conditions, like say road racing at Buttonwillow, constant high underhood heat can take a toll on stock wires.
I was going by what I have read in a sport compact article a while back, where they tested and said using an MSD SCI gave them what seemed to be a smoother revving engine, and slightlly better fuel economy (though fuel economy shouldn't be your top concern if you are worried about perforamce) (I take sport compact mag to be more of the 'performance' oriented magazine and not the "rice" stuff, though every mag seems to slowly turn into the "rice" stuff). When i said more spark more burn, i meant that the better (more voltage) the spark is, the less chance that the air/fuel mixture wouldn't ignite.
I personally don't like platinum plugs; copper conducts electricity better than platinum from what I understand. On all the hondas I sevice (my mothers's accord and bro's civic), i use copper plugs, and change them about once a year. They cost about $1.99 per plug, so it not that much of a maintentence expense.
