Torn Mind
Swapped some spark plugs after a P0171 popped up on my mom's Toyota Matrix. The plugs do look whitish(even with two of them having oil on the threads), suggesting a lean condition. I do not believe the intake manifold gasket is an issue, since i replace the defective version with the corrected version. I did a brief OBD check and the long term fuel trim is about 12% at idle and increase when the accelerator is pushed. On a test drive, the long term fuel trim goes up to 20%, indicating that the code was caused by not enough gas getting into the mix. The code is gone after the new spark plugs, but the poor cranking at start up and poor idle at startup is still around. The poor cranking first popped up after one time I overfilled the oil. The poor idle has been happening for almost 100k miles.
I'm thinking fuel injectors or coil packs, more towards the injectors. The engine code is gone but the whitish spark plugs are still a concern plus it's still guzzling fuel to compensate for the lean running conditions.
I'll probably spray down the MAF but I don't think it's the main issue.
