- Jan 13, 2005
- 2,158
- 0
- 76
Hello,
I have a problem: Just bought a used engine (2000 VW Golf 2.0L AEG)
I went to the place to check it out, did all kinds of tests to it (most importantly, I manually spun the crankshaft so I can see how the compression is and whether everything is in tact). I spun it a couple of times to be sure.
I came home, put the motor on the engine stand, and now when I try to spin the crank shaft, it spins halfway and it stops at one point. Something is preventing it from spinning, but I have no idea what.
The camshaft is fine, and so is everything else (they spin properly)..
Any ideas what could be preventing the crankshaft from spinning?
Thanks.
Moved to garage
AT Mod
Gillbot
Thanks.
Moved to garage
AT Mod
Gillbot
