Engine malfunction indicator turned on!!!
Serp86
671
Car is a three month old chevrolet/daewoo lacetti (in the US its sold as a suzuki reno i think).
Last time I drove it (about two days back), everything was fine, and engine was as smooth as ever. Today, I turned it on and engine malfunction indicator turned on after about a minute driving. Before it turned on i noticed that it was shaking a little too. After that I pulled over (had moved about a 100m from home) and turned it off. Then when i tried to start it again, it took longer to start, and during the drive home, it was always threatining me that it was going to stall. WTF is happening here? You don't expectthis from a 3 month old car
squirrel dog
5,564
48
I dont know if that car has vacuum hoses ,but that sounds like a vacuum leak . Could also be a plug wire loose.
Serp86
671
Could it be due to bad petrol?
Last fill up (week ago - haven't used car much since) wasn't from the usual pump - i'm starting to think that this might be the problem. I mean, from usage, the petrol in the pipes should be used up now, and i'm now on (bad?) petrol
Ornery
17
Plug it into an OBD-II scanner at AutoZone for free, or buy one for $40.00 or so. That will point you in the right direction. It does sound like a wire came loose though.
Serp86
671
I live in europe :(
God this is torture. Can't wait till monday morning - i'm gonna go to the dealer and kill somebody lol
imported_Phil
9,837
Doubtful. The petrol will mix with the remains of the tank when the car's filled up.
dud
7,635
73
Go to the dealer.
"Plug it into an OBD-II scanner at AutoZone for free, or buy one for $40.00 or so. That will point you in the right direction. It does sound like a wire came loose though."
Ornery, if this was a US car I would agree. I don't think foreign cars use the OBD-II standard (but I could be wrong). I think they use CAN.
Serp, a valve or sensor may have gone bad (since the car still runs). The error code is stored in you on-board computer's memory. The dealer will know how to extract it.
