I drive a '97 Toyota Corolla, 127k, but the engine only has about 100k on it. I've had it for a couple years now, and never had a problem with it loosing oil. Recently I moved from NY to DE, and made several trips back and forth (approx 600 miles round trip). After my second round trip, i checked the oil....or should i say i checked where the oil SHOULD have been. Instead, i pulled up a dry dipstick (no jokes plz). So i dumped in a few quarts, went to JiffyLube and had the oil changed. I have been keeping my eye on it, and it seems to only burn oil after being at highway speeds for an extended period of time.
- I do small amounts of highway driving to work everyday, and it doesn't seem to have much of an effect
- I have been checking the oil regularly (at least once per week) and it hasn't been burning much, if any
- There is no smoke coming out of my tail pipe, and i dont smell anything burning
- Since the oil change (about 2 months), i put one quart of oil in, and something my dad gave me that helps clean the engine out
- I do keep up on maintenance, and the oil had been changed less than 1000 miles before i realized it was gone.
- It is not leaking oil, i have checked under the car, and there is no consistent loss
I have heard there are some products out there that help seal up the engine and prevent this from hapening, but I'm leary on putting random shit into my engine. Or, do i have a more serious problem that is waiting to blow up on me? Any suggestions?
Thread Closed due to Necro-post.
Zenmervolt - AnandTech Moderator
