JEDI
2005 mazda3i AT, 175k miles
i replaced my sparkplugs myself last month with the same OEM iridiums that was in my car when i bought it new.
i'm on my 2nd gas tank (~500 miles).
after a stop, i accelerated like normal and the check engine light flashed a couple of times, then stayed on.
odb II scanner says PO304: Cylinder #4 Misfire.
1) which sparkplug is that? all the way on passenger's side or drivers side?
2) why would a new sparkplug cause that code?
if replacing the sparkplug doesnt fix it, then what?
