Which one is better for traction and control? I'm not talking about clutch wear or anything like that, just controlling the car.
I was talking with a guy at work about this short, icy (when it snows) section of road that's pretty steep with a sharp curve near the bottom. He said you should always engine brake on any icy hill. I am of the opinion that you want to avoid using engine braking since you get less control, and are more likely to lose traction compared to just using the brake pedal. I don't see the point to using it on a short little hill where there is no chance of overheating the brakes.
If you have a FWD car I can picture the rear end getting unstable and sliding out since only the front wheels are slowing the car down. I could see a RWD car as being a little bit better with engine breaking on the straight part of the hill since at worst the rear end will lose traction but won't be trying to go faster than the front on the straight. Even then, it's more likely to lose traction than using the brakes.
I can't comment on an AWD car trying to engine brake since I'm having trouble figuring out how the "power" would be routed when the engine is trying to slow the car down. I suppose this one could be ok since the AWD might act like an ABS system and transfer "power" away from the wheels that lose traction.
Am I missing something? Is there any situation where you would want to use engine braking to slow the car down when the normal brakes work?
